Input buffer needed for logging with AEM wideband?
Indian
618
Dec 15, 2009
Bishop, California
I Havent been logging my wideband values with dsmlink,and was going to wire my 0-5v reference wire into pin #15,but I read somewhere that in order for me to log values with the AEM wideband,I would have to use an ecu input buffer to work properly... is that correct? Any help is appreciated thanks! :thumb:
i wired mine to the rear o2 and no buffer need it. hope this helps :thumb:
We dont have a rear o2 sensor on our 1g's. Yes you need the input buffer to read correctly. I run it and its still off, you have to setup linear WBO2 in link manually to get a good reading. Myself am going to switch away from my AEM EUGO because I cant get good logging no madder what I try.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
