Innovative lc-1 with DSMLink
Xplicit93AWD
286
9
Jun 5, 2005
Miramar, Florida
I bought a lc-1 unit and I also have dsmlink basically I have no idea how I can get both working together. Has anyone here got there lc-1 unit connected with dsmlink I would really want to start tuning my car but I have no idea how to get them both connected with eachother. If someone can help me with this it would be appriciated.
Aramis:dsm: :talon:
Aramis:dsm: :talon:
Basically you need to run the wideband output wire from the lc-1 to pin 15 of your ecu. Pin 15 is egr temp, and it is a loggable input in dsmlink. For more information go to the dsmlink forums.
Once you have it run into the ECU, you must setup the LC-1 to mimic a wideband that is already programmed into DSMLink.
TEWBLin is the easiest one - conversion equation is 9 + (2 * VLin). So you would program one of the anaolog outs on the LC-1 to the following calibration: 0.00v=9.0:1AFR and 5.00v=19.0:1AFR.
Then add TEWBLin to your captured values on DSMLink, and it should log precisely.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
