Innovate AFR Gauges
olddsmer
158
Mar 26, 2010
middletown, Ohio
Hello to all and Happy Hollidays
Reading about the Innovate All in One wideband AF gauge MTX-L and the Innovate
DB gauge kit, I am not seeing much difference in their functionality. Are they essentially the same, or does one have more features and benefits? It looks to me that the DB kit is simply a bright digital display vs the MTX-L kit.
Any light you can shed is appreciated.
Regards
Greg
"Olddsmer"
The LC-1 kit is wired slightly different and allows for a separate sensor ground that the MTX-L unit doesn't. It also uses an external controller box instead of all the electronics being built into the gauge, which also means a bit more wiring.
In the end, the LC-1 is the one I'd recommend because of the sensor ground.
    • Sdcryan1
