420A Injector size
Inkdlyfe
438
8
Feb 23, 2016
Summer feild, Florida
Alright, running out of time, I dont have time for this back and forth tune... what is the biggest straight to the point injector size on a stock ECU fully built stage 2 cams 8.8.1 pistons u name it its done, the tune is just killing me in my area. Car will run on stock Injectors, 255 pump and fpr but will hit 8 lbs on stock injectors. What can I put into the rail to get more power running outta time..
Basically I'm just missing the 4g63 injectors and the fmu, I have a modified rail having a return line back to the tank along with a FPR on the return side of the rail causing the fuel to have to pass that first. I herd somewhere that u can put mustang injectors in ? Is this true ? Oh and I also do have a wally 255 pump too
680cc rochester injectors are about the largest that I would run if you want stock type of starting and idle on a stock ecu, of course you need someway to compensate for the size of them, either a chip or a reflash of a black box ecu.
So I found a set for 75$ but u said it needs a black box or tune I thought this was no tune
Yes those would need a tune, I wasnt sure on whether you wanted something easy to tune or something that would run on a box stock ecu, for box stock the Evo 560cc run good if you use the Evo maf with them.
I have a aem fic but I cant seem to get the tune right.. I got it to run but something is wrong. It wont go past 4.5k on the fic but if i take the 880cc injectors out and the fic. It runs perfectly fine. I just need this done asap due to import faceoff is in less then 15 days, so I'm trying to get it running on more boost with no tune
