Injector clip wire colors 97 gst
boost97gst
3,034
137
Apr 2, 2012
st jacob, Illinois
ok, im wondering(cause this car was a basket case) if somehow the injectors have been swapped on 2 and 3 all along. I get random cyl 3 misfire cel's. If i cycle power they go away and its very random.
So, my cyl 2 inj clip is green/black stripe and yellow/black stripe
cyl 3 is green/red stripe and green/yellow stripe.
Now, i know this is a wasted spark system but it runs identically if i swap the 2 and 3 clips. Now thats not right. Even doing a pull, back to back after swapping and reviewing logs the afr was the same in the same spots. The idle is the same. I think its right but i have to be sure.
basically, if anyone with a 2gb can go outside and check wire colors: I would seriously appeciate it. Thanks fellas
