initial start up and no oil press
I would guess at the oil filter housing gasket. Best thing to do at this point is to 1) call slowboy and rip on them and 2) Take the plastic cover off so you can see what is going on in their. Start the car and see where it is leaking from
thats my check list for tomorrow.............but why do u think the OFH?? Its not leaking by there....its all coming out right under the crank pulley
alright i called slowboy, and they said check the torque on the oil pump sprocket, they said if that isnt torqued right, that would cause a leak, but i doubt that big of a leak could come from that.....
oh i see what ur saying........slowboy racing installed my front cover so i am guessing that they did
yea i belive so, is it that cap that is in the bottom picture of that pic you sent me?? if thats not in there could that leak??
there is a bolt there, but what ur saying is that if that plug cap thing isnt in there, it will leak extrememly quick....like a half a quart in a few minutes like i had??
HOLY CRAP
So your ready to drop in motor had neither the required bolt of the freakin freeze plug in the balance shaft hole?!
Slow Boy sould give you some money for your troubles if this is true
u havta use rtv or some sealant around the bolt u used to cover up the bs hole or it will leak.and there supposed to be a plug right above the oil pump sprocket to,looks like a star kinda around the edges.l8r.
got it all figured out....and yea slowboy is giving me some credit on stuff i buy next time from them...thanks for everything guys
