Ingalls front kit problems.
Pro3racer
549
Nov 26, 2004
Stevens Pt./UW-Whitewater, Wisconsin
trying to install my Ingalls front camber bolts today, and the bolts seem too big to fit through the stock holes in my AGX struts and hub, is this normal??
How much too big. If it is less than a 1/16 of an inch you should be a ble to ream the hole with a drill bit to clean and open the hole. This wont cause you any problems at all. If it is like a 1/4 inch to big then obviously they sent you the wrong parts. Keep us posted. Travis
Its not a 1/4 too big, but its bigger, i'll try making the hole bigger and using a hammer to get it through, thanks.
