inconsistent boost!
terbear4god
Mar 26, 2010
sweethome, Oregon
my boost is really random im running a hahn super 16g with no shaft play with a ebay mbc
sometimes my boost will spike to 16psi than drop down 2-3psi or
sometimes itl only do 14psi and hold it...
is it just a crappy mbc??
i set my internal wastgate were its shut 100% and just were the rod barely slides on will opening the wastgate a lil bit fix my inconsistent boost??
im also going to harden the setting on my greddy bov..
any ideas???WTF
thanks
Check the routing for you vacuum line to the MBC too. Mine had a pretty good kink in it once that caused some inconsistency issues
i tried extending my wastgate arm and no luck so im gonna try putting it about 2 turns tighter than just sliding on the wastgate.. so itl be a 100% closed and have more tension on it..
i also tried tightening my bov and it just surged so i backed that down ill check for kinks in the line thanks!
it still does it is it normal if it drops like 1-2 psi by redline??
how tight should my wastgate arm be??
the actuator itself is 8-10psi so too run 15psi i have to create that little extra tension on the arm??
would i be safe have the arm about 2 turns after the wastgate flapper is fully shut??
alot of things can be involved . I was told awhile ago when I had my stock turbo running 15 psi that in first and second gear I would spike and drop about 2-3 psi and hold firm there was because of the ECU is not tuned to gold that psi someone called it " work load " but either way check your lines and are you recirculating ?
The big question is at what RPM is it dropping down. Are you doing redline pulls on it or is it just a quick "get to 16 psi" and then let off?
The spring in your MBC is either bent or just effed. Go buy a Hallman MBC LOL. Boost spikes are definetly not good
Same thing happened to my Ebay MBC. I would say as a good rule not to use the Ebay parts, seem to be subpar. I went the more expensive route and I got the AEM Electronic Boost controller w/ the better boost solenoid. No Problems since. Definitely do a boost leak check I was surprised at how many I had. Even a weld on my J pipe wad leaking:ohdamn: Good Luck!
