ekizenbe
- 89
- 0
- May 21, 2005
stony brook,
New York
hi guys. i just got my used cyl head from the junkyeard. it was from a 92 talon non turbo. what i did was i swapped over the cams from my old turbo head and it all seemed to go together perfect. anyway my question is that when u line up the dowels and the marks on the cam gears, should all thew valves in the head be closed or should some of them be kinda open. I think that the valves in the head are most def not bent because when the cams for the na motor were installed i remember seeing them all closed at one point. its just too bad i didnt note weather they were set up with the dowels and cam gear marks
anyway is everything ok with my head and i can go onto putting the intake manifold on?
