BkzProblem
- 214
- 0
- Sep 7, 2008
Brooklyn,
New York
I have been doing some research on blance shaft kits for my car... i saw this on AMS website... Now i know AMS knows their shit and this makes alot of sense.... Can Anyone tune in and give me some feedback.. Im not sure if this is just for the EVO because it was in the dsm section.... Here is the link to the website....
Automoto Sports Copyright© AMS 2006
This is the same Balance Shaft Elimator Kit used in all of our AMS built shortblocks. With this kit, you will be able to eliminate your balance shaft belt, while extending the life of your oil pump.
This is the same kit used in our 1000whp drag car and Record Breaking Time Attack car.
This kit includes:
AMS spec CNC Machined Race balance shaft
Clevite Balance Shaft Bearing
Block Off Plug
***NO CORE IS REQUIRED***
In our experience using a stub shaft when removing balance shafts can increase the chances of oil pump failures. This can be caused by the lack of support provided by the rear bearing on the original balance shaft. The support is needed to prevent the oil pump gears from pushing apart and wearing into the aluminum pump housing. Once the process begins the gears can continue and wear enough to cause them to seize. During this whole process the aluminum that is being worn away can enter the clean oil stream and contaminate engine bearings and other components causing them to wear prematurely.
To help prevent this process we have come up with a way to support the oil pump gears and still remove the rotating mass. We start with a stock balance shaft then, spin it in a lathe to make sure there is no radial run out. This ensures that the shaft will spin true in the bore and not cause premature bearing wear. We then machine the weights and extra material off in a precision lathe and re measure run out to verify nothing changed during the machining process. All parts get cleaned thoroughly and are ready for installation. In the pictures below you will see the differences in the three shafts available. There are also substantial weight differences in the three shafts as seen below.
This kit includes:
Block Off Plug
