im hoping this is the assembly
HaveSomeJoe
66
Jun 3, 2007
Portland, Maine
well, i had a master cylinder on its way but i canceled it because mine seemed fine, no leaks, no loss of fluid from the reservoir, same with the slave. Ive got about 3 to 4 inches of play in the clutch pedal so we pulled it and even with the pedal assembly removed, the play is still present, does this mean that it HAS to be a problem with the assembly?
problem solved. member Meh987 is a genius. The nut that holds the pedal to the assembly was really loose thats all. He's gonna weld it tomorrow as well because it is starting to wear a little.
