Ii know you can help~
mastaBO
96
Oct 22, 2003
THROTTLE CABLE PROBLEM
From the pics, the arrows are pointing to the cable running into the tube which you cannot see the tube in the pic. My question is, When i move that thing on the side on the second pic(like pushing the gas pedal), the cable does not go in the tube but stays the same without moving. Is it suppose to be that way? My cruise control does not work either. Could this be the problem of it?
I want to try things before i go to a shop to fix my tranny. Thanks in advance.
I think the question is a little vague... but you might just need to tight the accelerator cable...
To the left of that picture you show us following the accelerator cable you'll find bolts holding a bracket that in time is holding that "tube" that carries the accelerator cable, try losing them without taking them off, pull the bracket a little to the oposite side of the throtle, just enough to tight it, but try to make sure you're not pulling it, because it will be like you're somewhat accelerating all the time at iddle, try this and see if it helps, if not, expose whats going on... Im sure we can help you...
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
