ignition?
95customgst
55
May 13, 2005
Gulf Shores, Alabama
Ok like everyone knows my head had messed up and i had to change the oil pump, install a balance shaft elimination kit, had the head rebuilt, etc.
Ok today i got a mechanic to come over and install the timing belt correctly, now i can get any spark at all to the plugs, ive looked everywhere to try and find a lose connection, or something i didnt plug up, but i find nothing, my best guess would be the coil packs might be out? (the alternator is not hooked up...wanted to see if i could get it to work before i re-installed everything again) any help would be great.
Thanks
Diego Gramajo
1995 Eclipse GST
Check your crank and cam angle sensors. Make sure they are installed correctly, It is possible to have the crank angle sensor backwards which will cause no spark. Even if they are installed correctly you can check them via chiltons. If you need more info let me know.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
