Ignition
onisson
34
Jun 2, 2002
broussard,
ok my wife has broken my key in the ignition and I cant get it out. Has anyone had this problem and has tips on getting it out. Called POP a LOCK. thay spent about 10 minutes and gave up. Anyone have A diagram of the ignition so I can see if I can do this myself.
On many chryslers the key can be moved in to the unlock position and then a small button can be pressed in to release the key cylinder itself from the column housing. This can only be done of course if the key can be turned in the ignition. Maybe the use of a flat blade screwdriver could would help to turn the key if there's enough in there to trip all the tumblers.
Doug
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
