Ignition timing way off
MitsGSX
45
Oct 5, 2006
Seattle, Washington
My timing is showing about 13* BTDC at idle on a freshly re-built 7bolt 2G. what could cause it to be so advanced? and how can I fix it? thanks
idle bounces around a lot, from 1200 down to 400RPM. car runs ok between about 1100- 3000RPM, below it stumbles really bad, above it misses and pops like crazy. timing is 15* BTDC at idle, cam timing is dead on, checked it twice.
Did you either ground or unhook the base timing check connector (can't remember which it is you do.. i think you ground something)? The timing on teh 2g's is unadjustable because the cam and crank angle sensors are "fixed" and cannot be adjusted.
