Ignition timing adjustment - vr4
TorqueMaster
Apr 4, 2006
Farmington, Connecticut
I've searched all over the place, but I can't seem to find a good picture of the location of the ignition timing adjustment connector that is supposed to be grounded out when adjusting base timing. The only pictures that I've found are for a laser and from the service manual. I just can't seem to located the clip on my car. I'm not asking too much, just someone to take a perfect picture of the clip in their galant, and describe the position in perfect detail. Any takers?
I can't give you an answer to your question, directly, but you might head over to GalantVR-4.org and hit up the search. They have a huge forum full of write-ups, many with pictures. If you can't find what you're looking for over there, someone will have the answer, I am sure.
(And I'm not too far behind you. Mine should be running within a month!)
