Ignition set up question
zalock
195
Jun 17, 2002
Jamestown, North Dakota
Could someone tell me what a good coil, wires, plugs, combo would be for a 97 420A? I think im gonna go with msd for the coil but dont know about wires and plugs, maybe bosh plugs. Give me your opinions. Thanks,
Zac
DIS-2 is the MSD ignition box used on our cars. IT is similer to the CD ignition boxes used in older cars. The DIS-2 has two channels which means it can drive 2 coils. Our cars coil packs are actually 2 coil built into one housing. The DIS-4 is designed to work with 4 coil packs. Either box will work in case you find an unbelievable deal on a DIS-4.
Also i will throw in the "shop around" detail because Crane makes a very nice ignition box as well. Some people have had issues with MSD DIS boxes failing. I cant say i know much about how the box was wired in each car or where it was located but none the less the CD box did fail in 3 cases i have seen. Hahn prefers the crane box if you like to follow him.
Terry
