Fuel set up!
GabedsmT
Nov 27, 2007
Allentown, Pennsylvania
hey im a new member this is my 97 talon <a href="http://www.pikipimp.com/clicked/20932862" target="_top"><img src="http://hosted.pikipimp.com/pimped_photo/s/image/20/932/862/IMG00043-compiled.JPG" border="0" ismap="true" alt="my pimped pic!"/></a> thats my set up so far..... i have recently purchased 310cc from accel but i dont know what i should use to regulate pressure and the raise under boost load.... i have think about aeromotive fpr but idk if itll work.. does anyone has this set up... or how about the sfmu... but its really expensive... any ideas?
i forgot to mention i have an over size obx fuel rail so its easier for me to add the line for the fpr and just get rid of the stock fpr
Without knowing your goals, or your current setup (complete your vehicle profile), I can only speculatively say that an S-FMU may be right up your alley.
fuel:
obx fuel rail
fmu 12:1
walbro 255 lph
turbo:
t3/t4 57trim ebay
38mm wastegate(7psi)
2.5 piping
front mount intercooler
hks bov
fcd(pauls)
voodoo vacumm manifold
msd ignition
11mm obx wires
2.5" tsudo n1 catback(from the turbo no cats)
idk ### else u need to know, i want to put these 310cc. my goal is to gain as much hp as i can with the stock block... then rebuilt it eventually
You'd likely be plenty happy with an S-FMU. There are no cheaper options that allow you to run larger than stock injectors.
Not unless you're using Portfueler or MegaSquirt, or something of the like.
