PCD_RS
- 80
- 0
- Dec 2, 2007
Fort Polk,
Louisiana
My fuel set up for my 96 RS-T is:
12:1 FMU
Aeromotive FPR
340cc injectors
255lph pump
New OEM fuel filter
SAFC
Ok SO... I've been reading up on fuel set ups... The 340cc injectors and AFPR are what I just added to the mix. Now does this look wrong to you guys? I read up on some stuff where if I go bigger injectors I should toss my AFPR and get an SFMU... As of now I have no moolah for an SFMU. Also if I were to invest in an SFMU what brand or kind should I get? I know with the SFMU's you can change out the discs and adjust it for idle fuel pressure. That and I did a whole lot of reading on the 255lph pump... Read that it tops of at 120psi or something like that?? Any tips for my set up would be much appreciated
My other problem is with my fuel pressure. Ok so when you turn off your car... Is your fuel pressure supposed to drop to zero? Or slowly go back down to zero? Because I go to start my car and check my under-hood fuel pressure gauge it reads 35-40psi ish. BUT when I go to turn off my car the FP stays at the same pressure it was when I had started it. NOW is fuel pressure supposed to drop to zero when I turn off the car? Or slowly drop down to zero? Because my gauge SO VERY SLOWLY drops back down to zero. No clue what's going on WTF . Advice here would be awesome too and much appreciated! TIA
12:1 FMU
Aeromotive FPR
340cc injectors
255lph pump
New OEM fuel filter
SAFC
?? Or just pissy rich?
