Idling fine and then.....
91TalonTSiCT
224
Sep 24, 2002
Southbury, Connecticut
Well I got my car started after doing an engine swap and it was idling fine for about 5 minutes-oil pressure good, A/F starting to warm up and then the engine starts to stumble and the A/F starts to back down way lean. I have an auto tranny 1g with 14b, 450s, MT cams, and EPROM ecu. Could it be bad fuel or O2 or something else?
if its starting after your car is already warm it could be a leak. i had the same problem. it would idle fine at 1500 - 2k while cool then it would warm up and idle around 800 and it would start bouncing between 1500 and 400 and would eventually die, i did pressure test and found a leak in my hose that connects to the wg, was a little slit that only let air out under higher pressure and i didnt even find it until was went through all my hoses and rolled them around to see if they were cracked. well this one was. i cut the piece out and reconnected and it idles like a dream now. it solved my problem of running rich occaisonally as well. thats the first step i would try before dropping money anywhere else.
I should have mentioned before that Im using the Taboo vac setup, but I am getting a lean reading from my a/f when the car heats up. Any reason why this could be? :confused:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
