420A idles then stalls when given gas?
farmboy108
Jun 17, 2006
dover, New York
I finally got a used engine in my 99 gs and it started right up. It idles a little rough then smoothes out, but no matter what as soon as i hit the gas it struggles and then dies out. I have been told to check the vaccum hoses but i didnt see any place where they had holes or were broken. Any suggestions for what to look for? Thanks
If I try to give it any gas at all the afr goes all the way lean and it will die. Checked isc and it was bad replaced it now idles better and lower about 900 rpm but still dies when I touch the pedal. Disconnected the maf and it will rev up but a little rough. Also reset ecm. I have added alot of parts lately but it was running great.
I need help haven't been able to drive my car for 3 days.
I changed some stuff on my maft gen II that I didn't know about. Reset it now runs great again.
What mods have you added lately? Try backtracking on what you have done. Other than that I would check the translator settings and if that doesn't help try a different MAF sensor. Also check for any vacuum/boost leaks.
You called it. I somehow changed a few things on the gen II translator on accident. Runs great again. Thanks.
Having a similar issue, my car has sitting for about a year now and wouldnt crank dumped gas replaced filter and strainer on fuel pump. Now it idles fine but when given gas it start to die. When I try to rev it via throttle body i here backfire. Any input would be great. Thanks.
