Idles at 300RPMs, Boost in Nuetral....HELP
forcedlnduction
Oct 27, 2008
Clementon, New Jersey
Well I decided to do some wire tucking and ended up braking the T fitting that connects to the thermastat. I Rewired that and took abunch of vacuum lines out. Now I am idling at 300RPMS, barely any throttle response, and im making boost in nuetral. I know this is not good. Does anyone know how to fix this?
I removed the three sensors and vacuum lines by the AC fuse box. Looped the four ports under the IM. Have my boost line T'ed into the hose comming off of the end of the fuel rail and the one on the front of the IM. Looped the four on the TB. And looped the two on the thermastat....
Boost leak test it ASAP you must have missed a few.
