Car stalls in nuetral!!HEL:P!!
gsnoturbo90
106
Aug 5, 2005
East Norwich, New York
Alright this has been happening for quite some time and its only getting worse. After driving my car for a little and i pull up to a stop light and put her in nuetral the RPMs fall way low and the lights almost turn off and then it shoots right back up and falls right back down and repeast this getting worse and worse soon its gonna stall i know it. Any suggestions on what it might be what i could do to fix it? alright thanks guys.
99EclipseGS-T said:
Do you have an aftermarket bov? If so than check to see if it is vented, if it is than you need to recirculate it.
His car is N/T. Does the car sputter when at idle? Does it rev up past 1000rpm and fall below? LMK
Have your codes check to make sure all the electrical stuff is copacetic. After that checks out move on to other areas.
yeah well it shoots up to just around 1g and then down to like 300 almost stalling and then repeats. umm i would check the codes except i dont know how or what they even are any other sugestions?
