idle surge with new ISC
GsxEcutioner
1,549
5
Sep 3, 2007
San Bruno, California
So, before I replaced the ecu and rewiring the fuel pump, I had a normal running car, I replaced the ISC with a new unit since the old one burned out my old ecu, I replaced the ecu and added link lite and rewired the pump and got P0042 and had to rewire pin 13 to another 12v source in order to get the car to stay running. I now have idle surge and I have not touched anything motor wise except a new isc, I turned the biss all the way closed and still idles between 1000-2100 rpms. It just bounces around, anyone that might know whats up? Thanks
-Shane
oh Im mistaken, the CEL shuts off when the car is running, but it stays solid when its just on the last click with the motor off. get it? I use link and check DTC's.
Cel is on during run though right? And ill try the grease, btw how can the hack job do that? I just wired the mpi 12v to the fuel pump 12v.
-shane
I tried the connector grease, no help, i decided to just fiav blockoff, do i need a new gasket for the fiav?
It was the ecu -__-, i bought a junk ecu that did everything you described thats supposed to happen.
-shane
