Rock2610d
- 255
- 4
- Jan 22, 2013
Cheyenne,
Wyoming
Idle Log Kind of...Does it look ok?
My Elevation ranges from 7800 ft to 6000 feet.....thats why the 9:1 Compression.
Somewhat stock setup. Except: 9:1 compression, Fuel Pump Rewire, Eagle Rods, ARP head bolts, EVO 9 BOV, Cometic head gasket, Stock BCS mod, Balanced shafts removed and Catalytic Converter removed.
Well its not Link but I have a live data OBD2 recorder and this is what it says:
At Idle warmed up and nothing on....except cooling fan a couple times.
Calc Load % varied fro 17.6 to 18%
ETC deg F varied from 199 to 210 degrees
STFT B1% varied from -1.5 to 1.5 but mostly -.7 to .7%
LTFT B1% varied from -3.1 to -.7%
ENG RPM varied from 748 to 800 rpm avg around 760
Spark Advance degrees varied from 4 to 6.5 degrees
IAT varied from 73 to 75 degrees
MAF (LB/MIN) steady at .4
TPS% steady at .7%
O2S B1 S1 (Volts) varied between .119 an .760 alot
STFT B1 S1% varied between -.7 and 1.5% alot
O2S B1 S2 (Volts) Varied between .119and .860 alot
STFT B1 S2% varied between -1.5 and 1.5%
This is all the data my recorder captures.....do you see any issues?
TPS% steady at .7%
