Idle Drops or Shuts off
abc123
Dec 10, 2011
davie, Florida
Soo guyss! ive Replaced my Injectors. with another pair of used stock Injectors. and my car does the same shit it. it either Dropss Rpms then Picks up Or just Shut's off... any ideas?
Cleaned Fuel Rail and both Set of injectors Also Changed Fuel Filter. Spark Plugs. Coil Pack.
Any Ideas or opinions?
Yeah, my car does the same thing drops under 1k rpm then jumps over 1k and just keeps doing it. Does your car shake when it does this or is it just mine.
But I saw this in another forum though maybe it helps some.
"The only mechanical issue is the all too common low idle issue. Ive adjusted the Throttle Cable Plate and Im going to my friends soon to adjust the base idle speed in the ECU."
i would go an rent an OBDll an scan your car if u havent already done so if not try it, sometimes ive had not check engine light but the scanner would pick somthing up any ways , ill look in to it myslfe because i have both a 97 420a an 97 gsx
good luck
Does it do this all the time? Or just at certain times? I don't see your other post about what exactly it was doing to cause you to change your injectors and clean them. If you can link it to here or just explain it I might be able to see if I have an idea.
