Idle all over the place...suggestions
ChrisFlo
412
Aug 29, 2004
Tucson, Arizona
I've recently taken my 98 gst back to stock, and have had some trouble getting the car to run well. When I start the car, the idle holds steady at approx. 1k RPM, then shoots up to 2500 or so, then falls back to 1000. It continues to do this until I turn the car off.
Fixes I've tried:
TPS
MAP sensor
Front O2 sensor
ISC
Vacuum/Boost leak test
Spark plugs/wires (new)
I also have a new MAS on the way. Does anyone have any suggestions or experience with this type of problem? Anything will help. Thanks.
Chris
Fixes I've tried:
TPS
MAP sensor
Front O2 sensor
ISC
Chris
Do 2g's have a FIAV? (fast idle air valve)? If it malfunctioned, it could possibly bring ## idle up, even though it supposed to close completely after the engine reaches operating temp.
Generally 2g's will not have problems with leaking caps. As far as the FIAV, I'm honestly not sure if 2g's have them or not. Anyone know the answer to this and how to go about checking it? Any other suggestions will be appreciated. Thanks.
Have you tried to uplug the ISC and use only the biss screw? The ISC is actually just a stepper motor. I know it worked on my 1g not to sure about 2g's though.
IF your 2g has a FIAV I would work on blocking it. I did it on my first gen and not only did it ix my idle while it was warming up but also fixed the typical high idle i was fighting.
Do you have two coolant lines running to the front side of the TB?
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
