1G Where is the Idle Air Control valve on a 90
where is it located in a 90 TSI? pics would be nice if you can provide them
Looking from the inlet of the TB, its on the lower left side. Its got a big 6 pin connector on the back of it. I have an extra one if you need one. Ours are considered ISC as well Idle Speed Controller.
TB stands for Throttle Body, right at the inlet of your intake manifold. If you look at it (Where vacuum lines attach on the top) You want to look right under that part, and you will see the big connector undefined was talking about
nevermind, im an idiot, throttle body haha.
What im looking at, atleast what i think it is, looks totally different from what i have, its right below the throttle body and its the same shape but doesnt have a 6 pron clip plug its just wires going directly into it.
http://i.ebayimg.com/t/Eagle-Talon-Mitsubishi-Idle-Air-Control-Valve-/00/s/NTUyWDU4Mw==/$(KGrHqZ,!i!E6Qunzeh7BOvLRDdfyQ~~60_35.JPG
this is what i have
the one on the car doesnt have a connector like what i bought, it just has wires running directly into it.
NYCCDSM :: View topic - IS THIS MY IAC/ISC 1990 TSI AWD
if the 6 prong plug is on the other end of the IAC, and the new one i bought has the 6 prong on the IAC itself, how does that work
this is what i have
You bought the good kind, at least in theory. The blackies are better than the brown/tan ones. Although that is OEM, not sure if you got oem or what. There SHOULD be a 6 prong inlet on your ISC no matter which kind you have, like so:
I'm not sure what ISC doesn't have the prong, havent seen that, this means that its likely PO hacked the plug which is pretty lame. There are some adds on the classifieds where people have chopped up wiring harnesses to sell the plugs individually, can get one through there or get a wiring diagram and wire up direct.
the one in my car is like in the link my last post, there are a few pictures
Your ISC is for a 1990 TB, I don't think it's compatible with any other TB other than a 90. Same thing the other way around, not sure if the 91-99 ISC (such as the ones in the picture above) mechanically fits a 90 TB. If so the connector is the least of your problems. I have a bunch of both at home so i can check if for you later.
yeah see i got this one off rockauto for a 1g 90 specifically so idk
The two posted above (tan and black) are '91-'99 ISC's.
The metal one you linked to with the pigtail off of it is a '90 ISC.
'90 throttle body. You can see the ISC on the bottom right in front of the 2 nipples that stick out the side. The plug for it is on the left side of the throttle body.
yeah thats what i just noticed, so i gues i need to return the one i bought
  • For sale 1g MD122260
    Up for sale Discontinued MD122260 Forward Facing Oil Filter Housing $120.00 shipped plus paypal...
  • For sale 1999 Mitsubishi Eclipse GSX 5 Speed
    Selling a 1999 Mitsubishi Eclipse GSX. 5 speed manual, Red on Tan leather. 83,500 miles.
    • radron26
  • For sale 1g Carbon fiber center tail section
    Carbon fiber cover for center tail light light section
    • arodgst
