2G Idle Air Control valve causing surging?
dsmman91
192
May 23, 2011
Tricites, Washington
ok so i just replaced my idle air control valve cause it was causeing my engine to rev up my engine then go back down and then do it again but after replacing it the engine will still do it so what else could be causing it to do that please help.
First thing i would do is take your throttle body off and clean it with break clean and put new throttle body gaskets on it. My eclipse did that when one of my seals went out in my turbo and got oil into my throttle body. After i cleaned it and put new gaskets on it, it fixed the idle serge.
