Identify this coolant leak
mnturbo
Nov 2, 2004
minneapolis, Minnesota
I have a pretty disturbing leak from the drivers side of the engine
what is this this and what is causing this???
Please help me :cry:
We'd need real pictures -stuff large enough to put a stamp on, in case we have to mail them- but from the driver's side the inevitable answer is water pump.
Do the belts at the same time.
or the front case to waterpipe seal.. though to fixit right you might as well do the water pump and belts too... please note the water is coming from ABOVE those pics... you can see that it is trickling down.
To reiterate, the coolant isn't leaking from your oil pan. Look at/around your water pump, and rad hose. Let us know the progress.
I would suspect a hardened O-ring from the water pipe to waterpump. .27 cents and an hour in time. If thats what it is. I filled mine with water and squeezed the shit out of the lines forever til I seen it seeping out.
yeah I blew mine out when I had a bad rad cap that did not open after i shut if the car...
look inbetween the turbo and the front of the block and follow that water pipe with your eyes... If you get LOW on the radiator you can see where it is o ring'd ...
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
