I need wheel help!!!!!
RobAnd34
38
Dec 16, 2011
Ann Arbor, Michigan
Now I need help 1st question is the rear eclipse wheel hub a actually wheel hub or can I replace just a stud in it? Reason for that is because one of my studs somehow snapped off??? So I am riding on only four in the back right tire.. 2nd I just put on some 17 m1 rims I was having wheel rub in the back I fixed that!! no more rubbing but now my front right tire when it rotates (spins) it makes like a weird spinning noise.. like maybe its a bearing or caliper touching I have no idea please help so I can take care of this issue asap!!! THANKSSSSSS:confused:
for the broken stud you can just hammer it out and replace it with a new one or used one from junkyard and to press fit it in just put it in and then torque it down with the lug nut it self (pulls it in)
for the noice you gata see if the caliper hits the wheel but i do believe its the hub it self going bad since all your other ones are ok... how did you fix your rubbing issue? what offset did you get and what size tire?
Yokohama yk520's I think they are like 255's don't quote me though...? But I ghetto rigged my wheel rubbing problem I jacked my car up and then lowered it down slowly and jammed a 4x4 piece of wood in there and pried upwards and pushed it up and in. Ghetto fix but worked out pretty good! LOL haha
how wide a tire 9.5? as for they ghetto way you did it there's a simpler way use a 17+ long socket with a ratchet and simply roll around with the tire as a pivot point does a nicer roll with no need to lift car. whats your offset?
