I need to find this harness
ECLEVO4G
117
Aug 30, 2007
Stone mountain, Georgia
Does anyone know where I can get a 1g to a 2g CAS harness. I know that RRE and magnus sport makes them but is there anywhere else that sells them? They are backed up and keep telling me to call back towards the end of the week????????????????
Just want to make sure of this: you do know that the harness is not needed, correct? Even with very basic wiring skills, wiring the cas is extremely easy.
This is the wiring diagram. The connector at the top with 4 pins is the connector for the 1g cas. The other 2 plugs are on your current wiring harness and used to go to the cam and crank sensors. Your first step is to find these on your current harness.
Now, just connect the wires from your old 2 plugs to the wires for the new plug as shown in the diagram. Two wires from the old cam sensor will not be used, so just tape them up and hide them. The other 4 wires you connect to the 1g cas connector.
Listen if i did it I'm sure you can do it. I do it all but when it comes to wiring I get a little nervous. But hey it worked when I did it which has made me less hesitant to tackle a couple of those other wiring projects I had been trying to hide from.
  • Wanted 6 bolt NT water pipe
    • chrisman287
