I need pictures
ambcamry
36
Jul 12, 2004
Tehachapi, California
Does anybody have good pictures of a 14b install on a 2g car. I am putting one on my car but am a little confused on how all the oil and coolant lines run. Also will this oil line work. Were on the filter housing does it connect.
If your looking at the oil filter housing, the part that faces the front of the car has 2 allen bolts in it. You want the top one for the stainless line.
If you are still having problems, here is a site to help you with the oil feed line (your stainless one). The Oil return line is a gimmie, just bolts right up. For the water lines, you need to bend them a bit, but its pretty simple. One hooks up under the water pipe right before its 90* bend, and I believe the other one goes down to the oil filter cooler. Not sure on that last bit, but its the same as it was with your t-25, just need to bend them a bit.
http://www.roadraceengineering.com/instructions/oillineinstall.htm
OK so I am getting the oil line and a stock J pipe from a 1G. Is there anything else I need.
You should be good to go. Replacing the bolts and gaskets is optional. I used new ARP bolts, but reused my old gaskets. What intercooler will you be using...... stock??
    • george bromwell
    • pma1123
    • Sdcryan1
