I mixed up my valves...
sypherzero
461
7
Feb 14, 2008
Marion, North Carolina
So, for starters, I'm a tard. I know... I have a box that I punched holes in, and numbered them, to keep the valves organized. Well, our outside cat decided to become an inside cat and guess what he knocked over? So now they're all mixed up. I can tell exhaust from intake, but what do I do know? Is there anything I can do, or do I need to buy new valves?
Edit: I guess what I'm basically asking is are they 100% cylinder specific?
Im no machinist but i dont think it should matter for the most part as they valves rotate and whatnot.If your real concerned about it you could get a can of machinist dye (i forget the name for the stuff)paint the valves and see if they seal in the seats.
You have 2 sizes of valves.
The intakes will have the larger valve head than the exhaust.
Since they got all mixed up, I would take them to a local machine shop and have the valve faces ground.
This will put a new face on the valve and then lap the valves in the seat you want them.
Having the valves ground should not be much, a couple dollars per valve.
I'm gonna yo out on a limb and guess that you've never lapped valves before. If that's the case, I would take the head and valves to a machine shop and have them do all the work for you.
Hmmm.... That only sounds slightly condescending. I prefer to learn with actual hands on experience, when its something I can handle on my own. Thanks for your input.
Thank you Bogus, I appreciate it. Between you're help on here and Jafro on Youtube, DSMers everywhere have good, reliable resources to refer to.
Wear and mating of the valve to the seat.
Go have the valves gound, so they have new shiney faces on them, then lap them into the seat.
A semi-local shop to me does them at $3 a piece, and that adds up to $48 and approx $10 in gas each way totals $68. For just $50 more, I can get a new set of OEM valves or a set of std. size SS valves from Engnbldr. Do you, or anyone have any experience with thei Engnbldr valves?
The OEM valves you speak of, If they do not have the 6T on them, I will reccomend that they not be used in a turbo engine doing more than stock levels.
The Engnbldr Valves, yes I have used lots of them.
