I killed my car. Need help
1GBOOSTEDDSM
Jun 15, 2003
St. Louis, Missouri
I dont know what happened except I downshifted to second there was a hard jerk the car died and instead of sounding like its turning over the starter now sounds like its whining. when I tried to start it. Luckily I was a few blocks from my house. pushing it still sucked.
I watched the timing belt and cam gears,no tears, Timing belt is fine as I cranked the car. I dont know what the heck is going on. The starter cranks. My rpm needle moves a littble bit. but it doesnt sound like it normally does when cranking the motor. just a long constant whine.
So my timing belt is fine I think.
car doesnt start at all.
no fluids are leaking
I was only going 25mph...
Any ideas on how to fix it or what happened?
Thanks
Josh :dsm:
sound like you have no compression. since you were only going 25, i doubt these could be the problems, but usually that is the headgasket, bent valves, or rings. do you think it could have been any of those. i know when i bent a few valves on my isuzu rodeo when i tried craking it it whined really loud
1GBOOSTEDDSM said:
Yep im thinking a blown headgastket as well. I hope that is all it is.
thanks,
-josh :dsm:
Car's still run with blown head gaskets. hell I was able to start and drive one of my cars when i accidently forgot to put the spark plug wires back on #1 & #2... ROFL
Im betting your timing belt skipped a few teeth. Check all your timing marks.
