2G I have some interesting questions.
DsmDanielson
104
Jul 13, 2016
Peoria, Arizona
So I was doing research on the coolant lines to the turbo as I'm doing a turbo swap but ran into a speed bump with no luck searching through forums. The problem I'm having is my coolant lines are hitting the Allen head bolt underneath (see picture ) and I need to route the lines that way. Is the Allen bolt right there also a coolant passage? Can I remove the bolt and run the coolant lines to that opening and plug the top?
Stock coolant lines? what kind of turbo is that? We need some more information. Anytime someone searches through the forums I wonder if they are using the search feature on the upper right hand corner (Don't) or just typing in site:dsmtuners.com {your question here} into google, generally yields me very good results.
