turboConcepts
- 0
- Jan 13, 2003
Omaha,
Nebraska
well i may be crazy but i got money to kill, so im going to go all motor with this b*tch and see wut i can get out of her... any suggestions on mods let me know!!!!
, latermavisky said:titanium?? hahah
go forged internals, raise the compression while you're at it. then headers, test pipe, and catback.
nitrous isn't hardly "naturally aspirated" it's a power adder just like a supercharger or turbocharger
Uhh... yeah it is.GSGoinFast said:i dont see why they consider nitrous forced induction. yes, its not exactly naturally aspired, since the air its taking in isnt natural air, but the nitrous isnt being forced in.
That would be the extreme overkill, and unless you got thousands and thousands of dollars to waste, don't do it. (good thing you weren't really listening.turboConcepts said:my uncle says i sould go like titanium on pretty much the hole engine
)67goatpimp said:i don't think putting that much money into an N/A motor would be a good way to spend your resources....lots of money with not much to show for it. i would definately say throw a turbo, spray, plus everything else you're talking about you'ld be having some fun.
mavisky said:if your main goal is to be different no matter what anyone else says then go nt by all means. if you're looking to be fast for not alot of money, go turbo. my nt never got out of the 16's so i went turbo because i could care less what it took, i just wanted to be faster. if the quickest setup was a cow's ass stuck to my hood that's the direction i was going.
I'd likely go with an HKS 264 intake cam in addition to header/exhaust. I figured I'd drop in some 30lb injectors and use an AFC II to control them.
) and a custom built 2 1/4 inch exhaust. I thought about the ECU+, but with the AFC II I'd be able to see knock since I would be running high compression, and the highest octane we get in Cali is 91. Unfortunately, you can't just hook up a knock sensor to a volt meter, and I'd rathar not swap in a turbo ECU and buy a knockbox. I love what I've seen of the ECU+, and if it read knock I'd be all over it. I'd ditch the DIS-2 (for timing control) and just go with the ECU+ instead of the AFC II. Oh, 30 lb injectors equal something like 310ccs. You can buy high impedence injectors for our cars with the 30lb capacity. That way I don't need to fool with a resistor pack. It'll just be plug and play. Though I doubt I'll max those out with my setup. In addition, I will likely put in a fuel pump from a turbo 4g63. I'm currently using a stock turbo fpr with my B&M Commandflo AFPR which lets me lower the fuel pressure below stock for a 4g63 n/t.
