i did a compression test today
1990boost
41
Nov 29, 2011
brookfield, Connecticut
so i did a compression test today and here are the results, 1990 eclipse, 155,000 miles, from timing belt over is how i did it. 165-160-165-160 across the board, are these numbers normal for the 2.0 turbocharged engines? if so then i belive my engine is healthy and ready for a big 16g upgrade along with 550cc inj.
Those numbers look very good. Just as long as the compression is within 15 psi on all four cylinders and you're above the service limit, you have healthy compression. Before you do mods, you're going to want to do basic maintenance. Read the info at the following link for suggestions if you haven't already>Tech Guide: 1G 4G63t Upgrades - DSMtuners
