ECMlink I could probably cook a hotdog before this thing cranks over
Locis
Supporting Member
7
Apr 27, 2020
HINESVILLE, Georgia
As a last resort before I send the injectors to FIC to get looked over, anyone have any clue looking over this log as to why the car cranking for a million years ? Definitely well into the rich side on startup. This is on my Evo 8 but im running ECMlink v3 for clarification.
FIC 2150s. Resistor deleted. Has only seen 93
Radium double with 450/525 (450 is manually switched on) I have a consitent 43.5 reading at the afpr during cranking.
Omni 4 bar. Have an AEM 5 Bar sitting here to install incase the omni is deemed the culprit.
BPR8ES Gapped to .022
JDC Cop Kit ( All new Denso Coils )
Speed density
Compression test came back at about 145 per hole, chaulked it up to the GSC S3s and looser ptw clearance on the wiesco 1400hds.
Requires a little throttle to really get it going, especially from a cold start but once running, it idles smooth and drives perfectly fine.
I am at work. Can't read the log. If these are FICs, are you still running the resistor pack?
I'll update post but the resistor pack was removed, the pigtail is soldered and heat shrinked. Didn't have this issue before, sat for a while and sort of just started happening. These injectors have only seen 93 for about 5-6k miles or so
  • Wanted 1g WTB: '90 PTU
    Does anyone have a '90 PTU lying around? Part #md127742. Checking here before I buy one from...
    • Gabe92RTTT
  • For sale GVR4 Rare HKS Hi-Flow Intake Kit
    Rare HKS Hi-Flow Intake Kit $165 + shipping & paypal fees* For GVR4, but can also use on 1G *...
  • For sale 1g NEW Fidanza 6 Bolt AWD Flywheel
    NEW Fidanza 6 Bolt AWD Flywheel $250 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 Dejon Intake ( recirc )
    Dejon Intake ( recirc ) $90 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Black Top CAS
    Black Top CAS $90 + shipping & paypal feesYou must be registered to see element.You must be...
