ECMlink I cant get into Closed loop, or control boost.
GsxEcutioner
1,549
5
Sep 3, 2007
San Bruno, California
can someone tell me whats wrong with my car? I cant get into closed loop to get my Mafadjust.
-Shane
You Are in closed-loop... your barely going out of closed-loop an into open-loop since you threshold is set to 50% throttle & 1.40load in DA...
When your trying to use the MafcompAdjust you have to be capturing all the required values... with out CombinedFT, MAFRaw and ClosedLoop it will not work...
Also Make sure your logging at least these values...
ISCposition
A/C rqst Pin
FrontO2
LTFT LO
SDRatio
A/T D Pin
FuelFlow
MAF
SelectedLTFT
AFRatioEst
IdleSw
MAFRAW
Speed
Airflow
IdleSwPin
Mileage
STFT
InjDuty
OldAFRatioEst
ThrotPos
Battery
InjOn
Open Loop
Timing
BoostEst
IntTemp
P/S load Pin
TotalMileage
ClosedLoop
KeyStart
AirflowPerRev
PacketInt
TPSVolts
CltchSw
KnockRet
RPM
VE
CombinedFT
LoadFactor
RPM/Speed
WBFactor
CoolTemp
LTFT HI
SDAirflowPerRev
TPS Delta
A couple of those probably aren't relevant as I run SD
wait, my log has CombinedFT , Maf Raw, and Closed loop logging. what else am i missing? I changed the thresholds as said on one of the wiki's so that i can stay in closed loop longer, but because i cant log stft and ltft lo mid and hi, i cant maf adjust......
why is that? its in my graph but its greyed out as with all the fuel trims......
another log from just now.
