I can buy an EVO1 Eprom ECU for $100, can I use it?
SnowBird
527
Jul 9, 2006
Cleveland, Ohio/Tampa, Florida
A guy locally is selling an EVO1 Eprom ECU, I figure the fuel maps are different since they had bigger injectors and a 16G, I have a 90 AWD, can this be of some use though? The price is so cheap for an eprom I feel like I cant pass it up, and I actually have EVO1 cams, and a cyclone intake I have yet to put on, only thing is its set up on a T25 actuator.
Yes, you can use it. Make sure it has the knock sensor board on the main board. If you use it outright you can use a SAFC. However, if you go with DSMlink the chip will be replaced and it should function as any other ECU. Good find in my book.
