I built up my 420a, now how much boost? spent over $12k on engine!
Status
Not open for further replies.
mokeelokgsx
Jan 23, 2004
ashland, Oregon
420A recently rebuilt...
I am wondering how much boost can i lay down on this setup?
how reliable will it be?
ENGINE
JE Pistons 8.8:1 Bored .02 over
Eagle Forged Rods
Melling Oil Pump
Clevite 77 Rod & Main Bearing Set
Port & Polished Intake Manifold
Bored Throttle Body
Phantom LSD Slip Differential
Clutch Master's Stage 4 clutch
9.5 mm Plug Wires
Front and Rear Polyurethane Motor Mounts
Port & Polished Exhaust Manifold
Walboro Fuel Pump
Blue Printed and Balanced
Valve Job
Decked Head
Underdrive Pulley
2.5" Mandral Bend Magna Flow Cat Back Exhaust
Cold Air Intake
Lightened Crank
Shifter Bushings
Short Shifter
thanks!
you spent $12k on your engine yet you have a 2.5" exhaust rather than a 3"? where is the logic in that? not trying to be an ass by the way. just want to see your reasoning behind that:dsm:
You need some sort of engine manegment to be able to control your motor with out that you won't be getting that far with it
also it is hard to think that what you did coasted you 12k.:dsm:
only way i could see all that costing near that much would be if he brought it from a shop or direct from the manufacturer:dsm:
See now I'm confused... If you've put 12k into a cars engine ALONE, why the hell are thinking of trading? You must be either really old making around 60K a year, or really young and rather rich. :confused: :dsm: :talon: :laser:
no way did you spend 12 k on that ive got an all motor eclipse and ive done a lot of whats on that list and ive spent about 4500 if you did man you got ripped
ENGINE
BS BS BS BS BS BS BS BS
thanks!
Does your @$$ hole hurt? cuz you got fawked for $12,000, you couldnt spend half that if you bought every 420a item off howell auto motives website, unless getting raped for an install was on your list..
not trying to flame, but research your bs before you post
Amen to that. That is a hell of a lot of money to have spent! I hope you got extrude honing and Nasa engineers to work on your engine for that cost OMG I just bought my bottom end kit 2 weeks ago from Howell for $1,099.00 and with labor and the head rebuild I expect an extra $1500.00 to be thrown down. I hope you meant that as $2,000.00 and not $12,000 OMG OMG
I'v spent almost twelve on mt setup. turbo T3/T04E 60 trim, completely rebuilt engine, spec clutch, stage 5 axles, quaife LSD, relocated batery/got the red top stinger batery, exhaust (i too ahve a 2.5 in, becasue i bought it when i thought i wouldn't ever go turbo. I have a pretty tight setup it holds 20psi constant, and 25-28psi at the track. that engine build u have could hold quite a bit, but with out a new fuel setup your gona hit like maybe 240whp.
LOL...
hi guys!! i just dropped 12K on my engine so that i could turbo the biotch....but as soon as i wrote the check i found this awesome POS eclipse with the same thing done to it!!! so im gonna trade cars with him....oh and i found this awesome POS prelude!!! OMG OMG OMG im gonna trade my car to him too!!!..i cant wait...how much boost can i run to all three???!!?/ or better yet none of em!?!?!? do you think Paul Walker will drive my car?!?!? or maybe ronald mcdonald??!?! cause thatd be swell...specially if he power shifts OMG OMG OMG hes l33test driver EVAR RAAAAWWWR!?!?!?!? DSM4LIFE W000t :dsm: :dsm: :dsm:
Oh i forgot to metion I didn't tell you what turbo it was or what fuel or engin management I'm using. :rolleyes:
Once you can come up with a coherent explanation of what you are trying to do, please post again.
Status
  • For sale 2g sunroof shade cover
    I have 5 sets of these. They are freshly re upholstered. The material I used was black suede. I...
    • Jose gonzalez
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
