Hx40
Patrice tardif
Sep 10, 2014
St charles, QC, Canada
I have a mirage 89 turbo fwd 2.0l 8-7:1 smim big plenum 272 kelford set +2+2 ported head have install a holset hx40 6 blade in a v band precision in/out ar/82 im only see 20 psi by 5200 rpm and flow 50 lbs min a 8000 rpm do you think is good??
I run precision wg 46mm whit 9lbs spring but the housing is ar/82 people whit the 55 see 20 psi by 4100 whit small 272 no smim whit the ar/70 is 500-600 lower whit the 82 maybe 400-500 lower whit bigger cam kelford 272 is more like 280 cam whit big smim i think is like normal
Is why i ask for opinion but the top end is f***ing freak pull to 9000rpm no high egt compare to my hx35 in the bep55
