HX35 ebay turbine housing
More of a restriction than the BEP T3 housing, but will spool faster. This housing apparently bridges the small gap in spool and airflow between the Bullseye bolt-on housing and T3 .70 housing.
For about $30 more than the price of this housing alone you can pick up an entire HY35 turbo, which comes with a 9cm2 single-scroll T3 turbine housing that is nearly identical in spec to the .63 housing in the link above. We now have two HY35 users in the 10's.
