howell master performance rebuilt kit
Depends on what your machine shop says about your block. They may have to machine some stuff out, get your specs from them then order your kit
cyrez187 said:
what do u guys recommend for the Rod, and Main Bearing Size. standard,25, or 50mm?? thanks guys
I say standard rod not long
main bearing size will depond on whats in there now if you crank has ever been turned you might need a 30 or 20 over
my crank has been turned so i need 25 over bearings
you wont know what you need until you open your bottom end adn look at your bearings
they will be stamped with what ##over you need
or standard
also id like to add dont expect to get the kit till, oh, september.
i ordered their master rebuild kit for my cousin in january, and i just got it last week.
cyrez187 said:
ohh i pray to GOD my doesnt take that long, how about everyone elses take that long??
anybody from canada order anything off the howell site??
I havent ordered from Howell but they are known to take a long time for bottom end kits and bigger orders such as those.
  • Wanted 6 bolt NT water pipe
    • chrisman287
