jamel16
- 424
- 599
- Aug 6, 2004
Richmond,
Virginia
How can you tell if you have an eprom ecu ? What are the differences between eprom and non- eprom?
Is that saying that a non-eprom ECU can be converted to a eprom ecu w/ the use of a daughterboard utilizing the microcontroller circled in green?falcone4g63 said:
It says that, but the daughterboard when it was available was $700.project_tsi said:Is that saying that a non-eprom ECU can be converted to a eprom ecu w/ the use of a daughterboard utilizing the microcontroller circled in green?
steve said:It says that, but the daughterboard when it was available was $700.
Steve
The board included in the 1G DSMLink setup isn't a "daughterboard" per se - they call it a "memory board" - basically all it is is a CPLD microchip w/flash memory on board to allow changes made to the configuration to be stored. You still have to have an EPROM ECU to be able to use it.project_tsi said:Ok, but now the new version of DSMLink for 1G's comes w/ a daughterboard included. Is this a different kind or does it not act the same as mentioned on TMO's site?
huafist said:The board included in the 1G DSMLink setup isn't a "daughterboard" per se - they call it a "memory board" - basically all it is is a CPLD microchip w/flash memory on board to allow changes made to the configuration to be stored. You still have to have an EPROM ECU to be able to use it.
Just find an EPROM ECU on the trader or ebay. They can be had for about $300.
