How to tell if these are ARP???
fastclip
77
Nov 6, 2005
Saint Joseph, Missouri
I just got a block from a guy...6 bolt. Well it already has studs on the block....They claim them to be ARP...Are they and how do you tell...or is ARP the only one that makes head studs. Also can I order new washers and nuts from ARP, they dont have the washers or nuts??? Thanks guys
Arps have a stamping on them. Like this one.
James :laser::talon:
Generally if they are studs and not bolts they will be arp's, there are not to many other fastener companies that make stuff for 4g63's. And +1 for the stamps
Yea, I mean i was thinking that there was not too many companies making studs for blocks. But I just wanted to make sure....I will check the bolts tomorrow, will the ARP stamp be on the top(part going into the head) too. Also, since it has no washers or nuts, you think I can just get those from ARP
Have no idea. You will have to call them direct becuase i dont think any vendor sells just the nut and washer themselves. Also, the stamp will on only the top part. One side is flat.
Probably, but you might be abel to get them from an online arp distributor since i don't think arm sells directly to the public.
alright cool, yea I am too...I just bought BC stage II Cams, revised lifters, the retainers and springs, from them....So I will see if i can get them to add it to my order..was going to just going to rebuild my 7 bolt but found this 6 bolt bottom and all the block parts attached(oil,cooling, etc) for 400...Machine shop checked it out and it is in good condition so I am going to a 6 bolt bottom
    • Sdcryan1
