how to restrict my oil filter housing for my HX35
TofastForU_99
781
10
Mar 1, 2009
Kalamazoo, Michigan
I have currently been working on my 1g project with a hx35 i bought this oil feed line that feeds from the oil filter housing off ExtremePSI.com
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Oil Feedline Kit (Oil Filter Location): Mitsubishi Eclipse 90-99
and I started reading that Hx35 dont want any more then 70PSI. I have my balance shafts eliminated and the turbo is going on a slightly built 6 bolt. I have heard that you have to restrict the oil so you dont push to much oil. my problem is I dont know how to do this or really what it is can anyone help me and maybe post pics to? Thank you :hellyeah:
will that thread right into the line i got and the oil filter housing?
Yea it should fit just fine, i have the same type of line. I would put it on the outlet of the piece that screw's into the oil filter housing. If you put it right by the turbo, the oil stream may be higher pressure or off a bit because of the restrictor.
okay thanks a lot for your help if any one else does it different let me know
