How to Reset SAFC2!??
JoEgsX90
183
Jun 10, 2006
Yon, New York
Im purchasing this safc2 that came of a turbo tiburon....It was not reset, i was wondering when i install How do i reset everything or reset everything so my car run stock untill i mess with the tunning
Ok thanks man and with doingthat everything will just run stock untill i tune right?? Also when i start to tune instead of a wide band Can i Get away with using a DIGITAL readout A/F GAUGE reading of the o2 housing instead of a wideband??
No you need a wbo2. The narrowband a/f gauge is just a blinking light show. On pump gas I would tune to 10.9:1 afr with as much boost possible without knock. So make sure you get a logger an understand how to read a timing curve for knock.
Im not talking about the blinking light show one im talking about the DIGITAL gauge meaning number on it....Its just the digital AF gauge and you can just tap into your o2 sensor to get the reading from the o2 housing....I mean wouldnt that work..???
The "light show" and digital would have the same issue in that they're guesstimating the ratio based on an inaccurate sensor (the stock o2 sensor). You need a more accurate sensor like a wideband O2 sensor to actually make either of them mean anything.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
