how to remove VC sorry im a noob
DSM BoosT
150
May 5, 2009
hudson, New Hampshire
ok you take all the bolts on the outside of the VC and where the spark plugs go then.....?? do you need to take the bolt where the intake and exhuast camshaft are and remove that them take it off??? sorry not going to do something that will mess it up without 100% comfortableness LOL
You do remove every bolt that's on top on the valve cover and just lift it up. It has like 12 bolts or so.
o ok so dont even touch to shafts thx i couldve screw up this up LOL
I'm not sure what you're talking about but if you already removed the timinig belt cover and you're asking about the bolt in the center on each camshaft then no you don't have to unbolt them to remove the valve cover. You do have to remove the timing belt cover though .
LOL, forgot about that, but it don't need to be unscrewed you can just unplug the hose on it.
yeh it was stuck little bit of grease built up, just put a flat head under and pried it up came off easily thx, starting my process of cleaning then painting need to make some designs in photoshop to see what i like :)
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
